I have just blown the second Ignition Coil on my 1960 corvette.
When the first one went it burned the ignitioin wiring and was associated with a incorrectly wired ballast resistor. (who knows what caused what but I think that was related to a wire that was rubbing and shorted thru and shorted out to the ignition shielding - but who knows.) That was all repaired and car ran just fine - car died this weekend and the replaced coil is now cracked. The question is "just bad luck or something causing the problem?"
Any ideas would be most appreciated. What causes an ignition coil to fail?
Joe
Joe
