C3 68 orig AIR pump - NCRS Discussion Boards
C3 68 orig AIR pump
  • Jim T.
    • March 1, 1993
    • 5351
    C3 68 orig AIR pump
    Want to put some new bearings in my 68's air injector pump. Anyone done this before without sending it to a rebuilder? My service manual is not helpful.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 68 orig AIR pump
    Yes it can be done. I found the bearing locally after taking one out but it wasen't sealed. Some cautions are in order as I used some old yard stuff to pratice on and you don't want to pratice on original parts. Don't let the drum drop to the floor when pressing it out or the vains will break. When pressing out the bearing back up the alumnium case near the bearing or it will be damaged. The drum can be taken apart also but it is not easy.
    Lyle
