C3 1968 Quadrajet question - NCRS Discussion Boards
  • Jim B.
    • July 31, 2002
    • 146
    I am an original owner of a '68 convert 327 350hp HT block engine.
    Over the years I have tried to buy a backup carburetor, for use when I rebuilt the original. When I went to the dealer with the carb number , 7029224 code OB I was told that there was a mistake and that that carb did not exist. I checked with NCRS and the tech book says I should have a 7028219 code DG quadrajet. That was confirmed by the dealer so I bought one. The performance of my car went down significantly so I rebuilt and used the original carb. The '68 I have runs very strong and has 2 1/2 inch exhansts. I am now trying to restore it and would like any info on this quadrajet carb that I still have.
    Does anyone have any info on this situation?
    Thanks for any help.
    Jim Boudreaux
    Jim Boudreaux
    LA Chapter, NCRS
    _____________________________
    1968 British Green Convertible 327/350HP Original Owner
    2002 Z06 Black on Black Original Owner
    2007 Z06 Velocity Yellow w/Black/Titainium Original Owner
  • William C.
    • May 31, 1975
    • 6037
    Re: C3 1968 Quadrajet question
    7029224 shows as a truck application Quadrajet in the 44th edition Hollanders. That would cause it to carry richer jetting than the pass car variant. Generally, a Rochester carb that ends in an even number is for an auto trans setup.
    Bill Clupper #618
    • Clem Z.
      • January 1, 2006
      • 9427
      7029224 is a 1969 350 truck carb with 67 jets and 38 rods and with 7034320(AN) .070 dia tip secondary rods. 7028219 1968 corvette HP M/T with 66 jets and 36 rods and with 7034822(BG).040 dia tips secondary rods. at WOT the 7028219 is richer because of the .040 diameter VS the .070 diameter secondary rods.
      • Jim B.
        • July 31, 2002
        • 146
        Thanks for the response but I am still confused. There is no doubt that my Car was delivered with this carburetor in 1968 as I took it then. It hardly seems likely that a later carburetor could have been installed before delivery, so I will go back and recheck the numbers. I will post the results.
        Thanks again
        Jim Boudreaux
        Jim Boudreaux
        LA Chapter, NCRS
