1965 Saddle Interior Paint - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    1965 Interior Paint
    I have just painted the dash and interior components on my 1965 with PPG Medium Saddle Metallic. The original color seemed to be of a darker shade of Saddle or Brown than the PPG lacquer that was applied. The PPG lacquer has a golden cast to it. PPG states that this is the only formula they have for the 65-saddle interior code #421. Does any one have paint codes for Du Pont or RM lacquers for code #421 interior?
    Thanks Ray
    #36314
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • David Van Weele
    Re: 1965 Saddle Interior Paint
    I do not have the codes but what I did when I restored my interior, which I identified 5 different combonations of gloss, color and metalic on my 63 was to mix dark saddle, medium saddle, clear and metal flake. It took weeks to get it right but it was the only way I could get it right. This was back in 1980. I just kept shooting different variations and compared the match to my original parts.
    • Jack Layton
      www.autocolorlibrary.com/
      Was this site any help ? It lists the Ditzler numbers.
      • Bill W.
        • March 1, 1980
        • 2000
        The original int. was made up of different shades .the vinyl did not match the fiberglass or plastic. The vinyl also was almost 2 tone with light & dark spots.
        • Loren L.
          • April 30, 1976
          • 4104
          The "Low" (3 degrees gloss) used on the
          instrument panel, lower windshield garnish, radio speaker screen, heater outlet panels and seat and jack stowage wells is Ditzler 22596. The same low gloss on the headliner, rear compartment and console is Ditzler 22597. The "Full" gloss on the Windshield side and upper mouldings, halo panel, hardtop garnish mouldings, door upper/inner, kick panel retainer is Ditzler 22570.
          • Ray C.
            • June 30, 2001
            • 1132
            Re: The "Low" (3 degrees gloss) used on the
            Thanks! Ray
            Ray Carney
