I am trying to reconstruct my cec system which had been removed for an aftermarket intake/carb setup.
am I correct in that 1.a vacuum line goes directly from carb to solenoid 2.solenoid vacuum line runs to vac advance on distributor
the wires or plug that went to the solenoid are gone, what harness did they come out of?
How is the wiring for the temp switch in the right hand head incorporated into this system. Is it part of the solenoid harness?
