C2: Wiring Harness ties to steering column - NCRS Discussion Boards
  • Dan Pepper
    What kind of ties are supposed to be used to affix the wiring harness/hazzard flasher bundle to the steering column? There are a couple opaque white zip ties doing the job right now...
  • James W.
    • December 1, 1990
    • 2640
    Re: C2: Wiring Harness ties to steering column
    Dan,
    There is a black plastic sleeve that holds steering column turn sinal wiring harness. It is secured to the steering column tube via a small black plastic push-in clip. There is a small round hole on the bottom side of the steering column that the push-in clip fits into. This is located below or behind the instrument cluster. I have my complete steering column out right now. I can take a picture of it and send it to you via email. I can be contacted at jwest@oppd.com.
    James West
    Omaha, NE.
    NCRS #18379
    1964 Corvette #9258
