Power Antenna Removal - NCRS Discussion Boards
  • John Lokay
    I need to remove the power antenna from my 66" coupe which has under-side exhaust. What are the steps involved in removing the unit? Thanks
  • William C.
    • May 31, 1975
    • 6037
    Re: Power Antenna Removal
    Pull the muffler, unscrew the top nut, unbolt from the bracket, break the wiring connection, unscrew the ground strap and pull it out the bottom.
    Bill Clupper #618
