Theft Alarm/Wiring Diagram - NCRS Discussion Boards
  • Roger S.
    • May 31, 2003
    • 262
    The wiring diagram in the service manual shows two white wires on the connector at the flasher output side. One goes to the relay the second wire does not connect to anything. There are two white wires attached the the flasher in my corvette. One wire may to the relay, the other goes behind the carpet. Does anyone know where this wire goes and its function. In analyzing the alarm circuit I believe there needs to be a connection between the flasher and the door/hood switches to complete the circuit, a connection to ground, the wiring diagram from the service manual just does not show it.
    Roger
