69 427 tri power and intake ?s - NCRS Discussion Boards
  • kelly theaker
    -the 2 thermostat bolts on the intake should have what head mark?
    -the 1 bolt on the distributor hold down should have what head mark?
    -the throttle linkages for front and rear carbs, which linkage goes where? short or long?
    - and looking at the Paragon book they state that a small tang is used to hold the spring for throttle return , i do not have this , but the bracket thsat holds throotle cable does have a hole in it . Am i missing the tang or did this early 69 just use the hole provided on the bracket ?
    - the door ajar switch, rivets ,the one adjacent to the quarters, was this bracket installed before paint or after?
