1966 Gas Tank - NCRS Discussion Boards
1966 Gas Tank
  • Wes Price
    1966 Gas Tank
    I just bought my first Corvette, and I thought I had done quite a bit of research, but I was surprised when I went to fill the car up for the first time. The gas tank filler neck is huge (probably 3.5 inches in diameter)...almost like an aviation filler, there is no smaller hole for the nozzle. Is this typical or do I have an aftermarket/homemade tank? Thanks
    Wes
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 1966 Gas Tank
    Wes - this is the correct normal filler neck for vettes...that way for many many years until the unleaded came out....don't worry...Criag
    • Jim T.
      • March 1, 1993
      • 5351
      Re: 1966 Gas Tank
      Wes this is a plus feature in that you can see into the tank and see how much gas is in the tank. It also makes it easy to clean out. You can see good enough into the tank, at least on my 68 and 70, to verify that there is not anything but pure gasoline in the tank. I once go water in my 70's tank, very easy to remove the gasoline and then clean the tank. I removed my filler attachment to the tank and was able wipe it out by hand.
      • Frank Hare
        Re: 1966 Gas Tank
        It does come in handy,I had a 67 the gas gauge floated all over the place.After driving it a couple weeks I thought I would investigate,after pulling a open can
        of 104+ octane booster and a red shop rag out of the tank,not only did the gas gauge work but a pesky rattle was gone too.
