Has anyone used multiple front crossmember shims on a C1 to get correct camber? Thanks...Ed
C1 Front Crossmember Shims
Re: C1 Front Crossmember Shims
no need for muliple shims if frame and/or front suspension components aren't bent. take chassis to local body shop with good frame straingtening equipment and have them check out its measurements. bgood luck, miike- Top
That is what I thought, but at max positive adjustment, the camber on both my front wheels is negative a half a degree. I had heard an extra shim might somehow help, but I wanted to see if anyone else had tried this technique. Back to the drawing board. Thanks...Ed- Top
