Both '65 AIM and '65 Shop Manual Supplement call for 14-18 ft.lbs for the U-bolts on both ends of the propeller (drive) shaft and the (small block) half-shaft U-bolts at the differential pinion(s) [even though the differential U-bolts are larger than those of the driveshaft].
This torque range seems low -- heck, my torque wrench scale starts at 20 ft.lb. Also, the big block differential pinion cap bolts call for more than double (40-50 ft.lbs) the U-bolt torque.
Is this 14-18 ft.lb correct ?
