I installed my trailing arms with a new bolt kit from an aftermarket source. The hole for the cotter pin was past the top of the nut and would have been ineffective. The assemble manual shows a lock washer that was not in the kit I bought. The washer would have to be 1/8 thick for the pin to be in the castle nut correctly. Is the lock washer this thick or is it possible that someone cranked down the nuts without enough shims causing the frame to pull in? The manual shows what looks like a toothed lock washer and they are usually on the thin side.
Tom S
Tom S
