67 tri power exterior leak - NCRS Discussion Boards
  • Roger Konkel
    Ok, thanks for everones help. I replaced the metering plates, front and back and no more internal leak. I also replaced all of the gaskets, acc. pump. Now the problem is that when the car sits for a day or two there is gas at the bottom of the manifold. It looks like ti is coming from the center and rear float bowl. I have removed the carbs three times now and replaced the gasket with no luck. Any Ideas?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 67 tri power exterior leak
    the gas is boiling in the float bowls after shut down. lower the float levels about 1/16" to 1/8" and see what happens. the best fix for this is to block the heat riser crossover in the intake but you loose your heat for the automatic choke.
