Re: stuck Vet hood. - NCRS Discussion Boards
Re: stuck Vet hood.
  • David H.
    • December 1, 1996
    • 241
    Re: stuck Vet hood.
    there is a black plastic plug on the upper firewall panel which is in line with the hood latch. reach behind and under the hood with a long screwdriver and push out the plug. then continue to push through the panel and on the latch tab, push forward. this will push on both sides as they are conected with a cable on the hood. the passenger side may also have a plug. David
