I recently had engine rebuilt for 270hp and installed many correct & dated items. Two "leftover" parts were not installed. GM part # 3744408 spark plug wire clip/support on block (pageA110 in assembly manual) and spark plug wire clip-Oil pan, part # ?. These were in Corv.Central Ignition shield kit. Question is, I can't see if old ones were used or these were just omitted from rehaul on engine compartment. The clip on the block is under the generator and spark plug heat shield. Are these important? Is there an easy way to see them? Would any deductions be made in judging because of there absence? Thanks for any input...Bruce #39024
61 leftover part?
