Here it is the night before we leave to go to BG and our LS5 is acting a little lazy ... here is the scoop ... good clean raditor, good water pump, nice mixture of antifreeze to water (50/50 mixture) all good hoses, good fan clutch, new termostat ( can not remember if it is 160 or 180)... all the seals around the rad are there and in good condition .. BUT here is the surprise .. at highway speeds 60 MPH the temp rises to about 210f (and that is when the temp was around 80F outside) ... if I then take a "back" road and run at 40 MPH the temp drops down to around 180/190 F .. The only thing that I know for sure is that the timing is just a little advanced so to 10/11 degrees Vs the books suggestion of 8 .......I have thought about pulling the thermostat for the trip .. but I really shouldn't have to do that ... A friend of mine (who races) suggested retrading the timing to about 6 degrees ... he also feels that I am pulling additional air into the intake manifold because the gasket under my gas cap is gone (it is a "sealed" cap) .. this too will make it run lean .. thus hotter
what are you thoughts and suggestions ...
