L71 Tri Power Center Carb - NCRS Discussion Boards
  • John M.
    • January 1, 1998
    • 813
    I have a 69 L71 and the center carb has a vent assembly on the top outside of the carb bowl.
    I'm working on a 67 Tripower set up with service carburetors. The center carb does not have this vent. The picture shown in the 67 chassis service manual has no vent and interestingly, the 69 manual has a picture of this setup with no vent. Is this vent neccessary and are the carbs otherwise identical? Thanks
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: L71 Tri Power Center Carb
    yes they are identical and if you look the carb throttle linkage it has the arm on it to operate the bowl vent. just had this same question put to me the other day and the guy drove the corvette to BG with our caravan with no problem with the carb. he has a TI problem i have to solve but that is another day.
