C3 (1968) L36 Choke Rod Installation Problem - NCRS Discussion Boards
  • Henry J.
    • November 1, 1999
    • 457
    I am having trouble installing a new choke rod on my 1968 L36 (427/390HP) so that it doesn't interfere with the adjacent choke return spring on the carb. Both the intake manifold and Rochester carb are correct. The thermostatic choke spring mechanism, choke stove housing, and choke rod are new (from Paragon) and I believe them to be correct and are precisely as illustrated in the Paragon catalog.
    I am aware that some bending of the rod may be necesssary, but I am unsure of how best to do this. The AIM doesn't have an illustration of the desired choke installation details for the L36, so it isn't much help.
    I would be very pleased to receive an electronic photo(s) of an installed choke assembly from anyone owning a 68 or 69 L36.
    Thank you in advance for taking the time to help me.
  • Michael M.
    • February 15, 2007
    • 455
    Re: C3 (1968) L36 Choke Rod Installation Problem
    I have a 68 L36 but I have since ditched the choke stove for an electric unit. I don't have a picture and it is obviously hard to describe how to do something like this using only words but I do not remember having any real trouble installing the choke rod. Is it possible you just have it facing the wrong way? Also, you say the carburetor and manifold are correct but I do not recall a choke return spring on my carburetor. Of course mine might have been incorrect. Anyway, is it possible you have a different airhorn on your correct main body of your carb? You may want to check into this.
    • Henry J.
      • November 1, 1999
      • 457
      Thanks Michael. I'll do the checks that you suggest.
