1968 L36 Harmonic Balancer P/N - NCRS Discussion Boards
  • Henry J.
    • November 1, 1999
    • 457
    I had to remove my harmonic balancer as it was cracked at the keyway. The number cast into this balancer is 3860060. It is doubtful that it is original. My references show no such number. Is anyone able to identify its original application? Thank you.
    Re: 1968 L36 Harmonic Balancer P/N
    Henry-----
    The number 3860060 which you found is not a balancer part number. It is the casting number for the hub portion of the balancer assembly. The part number for the balancer assembly is GM #3860008. It's still available from GM for a current list price of $272.37.
