I am looking for the GM numbers for the alternator and PS belts for a 1967 327/300 W/O A/C. Thanks.
1967 GM Belt Numbers
Re: 1967 GM Belt Numbers
Paul-----
The current GM SERVICE belt part numbers are as follows:
alternator----GM #9433759
p/s pump------GM #9433725
Both of these are 7/16" wide belts as compared to originals which were 3/8" wide. The length of these belts is slightly longer than the originals due to the change in belt width.
Original belts were "wrapped" construction; the above are "cut" construction. All Corvettes since 1973 have used "cut" belts. Wrapped are, generally, only available in reproduction from sources like Quanta.In Appreciation of John Hinckley- Top
