57' Powerglide Shifter Assembly - NCRS Discussion Boards
  • Bob A.
    • April 1, 2003
    • 172
    Does the spring rest directly on the mounting bracket or is there a flat washer or a spacer of some type between the spring and the mounting bracket? As always THANKS for the valuable information.
    Best Wishes!
    Bob
  • Pierre J.
    • July 31, 2000
    • 193
    Re: 57' Powerglide Shifter Assembly
    Bob,
    I have the PG shifter out of my '56 now. I'll check it tonight and let you know.
    Pierre G. Joly #34410
    • Pierre J.
      • July 31, 2000
      • 193
      Bob,
      I did check the shifter on my '56 and ther is NO washer between the shifter frame and the spring.
      Hope this helps.
