Re: Removing Paint from Stamp Pad
At a Western NY Chapter meet, I was told to remove the paint from the engine stamp pad...or...take the hit. I took the hit on points but cleaned off the paint when I got back home. I used lacquer thinner applied carefully and frequently with a small camel-hair brush. Then rubbed with a lacquer thinner-soaked cloth. To remove the paint imbedded in the stamped numbers and letters, I took a large sewing needle and carefully followed each indentation while applying more lacquer thinner and ..VOILA !!! IT WORKED...NO PAINT. GOOD LUCK. Dick # 31008
