What will it take to change a 2 bolt 1969 512 427 engine block into a 4 bolt 435 hp block.
I know I can have the main caps machined and then with new 4 bolt caps have it center lined bored so the caps are straight, but is there anything else I need to do for this restoration...
I have read that all BB had been drilled for Oil cooler conections and I have also been told that my 435 hp car was not set up for this so the block was not drilled for the vettes?
Is there anything aside from the main bearing caps that I need to have done to make it right?
