66 sounds low on oil - NCRS Discussion Boards
  • Mike McKown
    While you are checking the valves/rockers
    Record the lash setting (or lack of it) and then pull a few rockers and look at the tops of the valves stems. If they are rounded off, this will also cause noise. Re-install your rockers to your recorded lash setting and contemplate your next move.
