Dash Wiring C2 65 - NCRS Discussion Boards
Dash Wiring C2 65
  • Mike M.
    • September 30, 1999
    • 710
    Dash Wiring C2 65
    I,m installing a new wiring harness from Lectric. On the right side of the dash wiring I have 2 wires each with a plug on them. One is black with a white stripe, the other is black with a orange stripe on it. I cannot locate these on the wiring diagram. Anyone know where these go or what there for. Everything else went great. Thanks Mike McKenzie
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Dash Wiring C2 65
    B/W sounds like the door switch for the courtesy lights. B/O may be the glove box light.
    • G B.
      • December 1, 1974
      • 1407
      Black w/orange or vice-versa?
      That wire sounds like the glove box light if it has a male copper spade terminal.
      The white one goes to the right door jamb switch for the courtesy light.
      • Mike M.
        • 710
        Re: Black w/orange or vice-versa?
        The wires come out with the dash cluster with the dash lights, ignition swithch ect. in the right hand grouping for the instrument cluster. one is black with a white stripe, the other is black with a orange or browm possibley stripe. They are long enough to hang down below the cluster and te plugs on them are similiar to a capictor connection. Hope this may explain them better. Thanks Mike
        • Wayne W.
          • April 30, 1982
          • 3605
          First you need to learn left from right. The driver side is the left.
          • Wayne W.
            • April 30, 1982
            • 3605
            The individual wires in that area are the radio capacitor(brn), cluster ground(bk), and cigarette lighter(or) These are 67 colors.
            • Loren L.
              • April 30, 1976
              • 4104
              Black w/orange is the heater fan motor;
              black w/white goes to horn relay.........I think...
              • G B.
                • December 1, 1974
                • 1407
                I retract my comments
                I have no idea what part of the harness we're even talking about.
                Shame on me for jumping in so quick. It won't happen again.
                • Wayne W.
                  • April 30, 1982
                  • 3605
                  Re: I retract my comments
                  Orange and black is also the lead for the clock, but thats in the center, not right or left.
                  • Mike M.
                    • 710
                    I got called to work and I'm not at home to sort this out. Thanks and I'll try and go through this when I get back in a week or so. Thanks Mike
