'64 alignment specs - NCRS Discussion Boards
'64 alignment specs
  • Randy Adams
    '64 alignment specs
    Does anyone know the specs to align a '64 w/o pwr steering & with radial tires. I am rebuilding the suspension and don't want to mess her up. Thanks
    • 15610
    Re: '64 alignment specs
    Recommend zero camber on the front, minus one half on the rear, 2 degrees front caster, 1/16" total toe in on both ends.
    These are for normal mild driving.
    If you drive in a sporting manner and like to push the limit, increase the camber on both ends to about negative one. More caster will increase on center steering feel and wheel returnability. It comes down to personal preference.
    Regardless of whether you want the "base" or "sport" alignment, I recommend hard urethane bushings on the front anti-roll bar links.
