overspray 59 - NCRS Discussion Boards
overspray 59
  • Robert D.
    • April 1, 2003
    • 305
    overspray 59
    is there supposed to body color overspray anywhere in the engine compartment frame or wheel wells?
    thanx
    bob
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: overspray 59
    Bob - Typically, you should not see any body color overspray on the frame. The engine compartment would show body color, but, when engine compartment blackout was applied, it would be "over colored". In other words, if you strip the engine compartment paint, you would first see black out, then body color, then primer, then raw fiberglass. Wheels wells are going to show a little primer, then a little body color, then blackout. Best, Dennis
