C3 Headlight Door - NCRS Discussion Boards
C3 Headlight Door
  • Don Justham
    C3 Headlight Door
    One of my headlight doors on my 1970 is rubbing when it lifts up. Any tricks to adjusting it? I have loosened the three bolts on each side and am not having much luck getting it adjusted so that the upper lip of the door doesn't rub on the body. Any help would be appreciated. Thanks
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: C3 Headlight Door
    Front/back or side to side. If side to side, there are stops on each pivot shaft that will allow adjustment.
