67/427/400hp header - NCRS Discussion Boards
67/427/400hp header
  • Roger Konkel
    67/427/400hp header
    I decided to have the valve covers repaired and repainted. I noticed on the header on the drivers side on the back side of the header is a very large threaded adapter into the header with a temp sending unit threaded into the adaptor. Not sure why the sending unit is there and it came out real easy but I can't get the adaptot loose. Is that suppose to be there or is it suppose to be a flush plug like on the other side of the car. The headers are correct for the car.
    Roger
    Re: 67/427/400hp header
    Roger -
    Are you referring to "header" as in tubular exhaust headers, or do you mean "heads" as in cylinder heads?
    • Tom D.
      • September 30, 1981
      • 2126
      No temp sender boss on heads, if the heads are correct for 1967. Tube headers could have something...
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
