I have read the cautions regarding working with transister ignition; don't remove and check for spark at more than 1 plug at a time, and I believe the other is don't disconnect the coil wire. I want to re-check my fuel lines (tri-power) for leaks without trying to start the engine. What is the best way to dissable the ignition, while dissconnecting as little as possible?
'67 TRANSISTER IGNITION CAUTIONS
