i'm needing a 63 hood and would like to know the difference between a 63 and a 64. i'm trying to find out if i can use a 64 and install the hood grills.
63 / 64 Hood question
Re: 63 / 64 Hood question
I'll let others answer on the grills. Another consideration is the hood allignment blocks. On a 63 depending on the build date and depending on the model coupe/roadster, there were either 2 or 4 or no allignment blocks. I do not believe the 64 hood has the 4 bolt plates installed between the upper and lower glass that makes up the hood. The blocks are normally white plastic held on by 2 bolts.
Harry
38513- Top
