Coil bad? - NCRS Discussion Boards
Coil bad?
  • Nick Vigorito
    Coil bad?
    I bought a 202 coil at a swap meet. The guy didn't know if worked or not. I measured it and the primary resistance is about 1.5-1.6 Ohms and the secondary resistance is about 11,600 Ohms. My service manual says 1.24-1.46 for the primary and 6500-9500 for the secondary. I can't test it in my Corvette at this time. Is it bad or worth keeping to try out in my car? Thanks in advance
    Nick
  • Dave S.
    • August 31, 1992
    • 2918
    Re: Coil bad?
    Nick,
    Don't throw it away. The only way I know of to properly test an ignition coil is to run it on a car and get it nice and hot. Contunity tests are not fully reliable. You can put that #202 on any car to test it.
