Can anyone out there tell me how to cancel the "Change Oil" idiot light on a 1993 corvette????? Thanx
idiot light
Re: idiot light
Billy,
I assume that you've looked in the owner's manual, and its not there?
If no luck, e-mail me direct (if possible, today) as I will be by a 1993 service manual tomorrow.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Re: idiot light
Billy,
Re: idiot light
Hi,
Place the key in the ignition & turn it to the 'run' position. Do not start the engine. The dash display will light up. Locate the 'ENG MET' button on the display panel. Depress this button & release it, then depress it & release it again. Next, depress the 'GAUGES' button.
You will then see the 'CHANGE OIL' light flash. Keep depressing the 'GAUGES' button until the 'CHANGE OIL' light goes out.
Hope this helps.
Fred O- Top
Re: idiot light
Hi,
Hope this helps.
Fred O- Top
