'67 BIG BLOCK HEAD BOLT TORQUE - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    The chassis service manual and two other engine rebuild manuals I have call for 80ft lbs on all the cylinder head bolts on big blocks. I have another book that calls for 65 for the short bolts, and 75 for the long, which I believe is correct for only aluminum heads. Can someone confirm the proper torque and whether it is different for the short and long bolts?
    Re: '67 BIG BLOCK HEAD BOLT TORQUE
    Rob -
    The Chassis Overhaul Manual torque specs show 80 ft-lbs. for all bolts on iron heads; the aluminum heads show 75 for the long bolts and 65 for the short bolts.
    • Clem Z.
      • January 1, 2006
      • 9427
      that is only true if you are using GM head bolts as other bolt manufactures may have different specs.
