I have a 65 4-speed car that the driveline starts vibrating/shifter buzzing at 60MPH or so and really doesn't get worse(just buzzes w/ a higher pitch) as I increase in speed. As I started my investigation- I'm thinking it's coming from the driveshaft. As I was unbolting the shaft from the diff- I found three original bolts and one "ace hardware" bolt- that looked like it had Bubba's fingerprints on (see pic). The bolt is lighter and shorter- would this be the culprit or should I look deeper?
Thanks-
Richard
Thanks-
Richard
