Re: C 1 Antenna - NCRS Discussion Boards
Re: C 1 Antenna
  • Bud Landacre
    Re: C 1 Antenna
    I remember t******* the antenna on a c-2 years ago. There is an adjustment screw on the radio case that allows you to do this. I believe it is accomplished by tuning to an AM station with marginal reception the turning the adjusting screw to a position that give you the best reception.
    Regards
    Bud Landacre
  • Harry Sadlock
    Re: C 1 Antenna
    It's best to have the antenna up. Try to get it as close to a meter as possible prior to making the adjustments.
    Harry
    38513
