C3: L46 5 blade fan - NCRS Discussion Boards
C3: L46 5 blade fan
  • Dan Pepper
    C3: L46 5 blade fan
    The fan on my recently purchased '69 L46 coupe looks like it may be for a '66 AC car. I'd like some help confirming that is is or is not.
    The fan was obviously added at some point because it had been chromed. It's a 5 blade fan with what appears to be a heavy pitch, and about 17.5" diameter at the widest spread of the blades. It is stamped with "FRONT", "66" and "W" on one side. Also has square rivets, rather than mushroom type.
    Interestin thing is that it looks identical to the original fan on my '66 BB AC car (which, by the way, is slightly tweaked and needs replacing). Note that the original fan from the '66 does not have "66" stamped on it. Otherwise, the fans look identical in pitch and diameter.
    Were there any PN's stamped on original '69 L46 fans? Thinking about cleaning-up/spaying over the chrome and using this fan on the '66 and getting a "correct" replacement for the L46.
  • Tom S.
    • March 1, 2004
    • 1087
    Re: C3: L46 5 blade fan
    Dan
    You didn't say if you have air on the L-46.But the car could have a 5 blade even if it has air.It should be gloss black and none of the 5 blades have date codes.The one for air cond. cars will have a greater pitch.Hope this is of help.
    Tom
