C1 clutch cross shaft - NCRS Discussion Boards
  • Pat #25912
    Once the springs and linkage have been removed, is it just a simple matter of unbolting the bracket from the block and lowering the clutch cross shaft away from the frame bracket? Thanks in advance. Pat G.
  • Mike E.
    • February 28, 1975
    • 5134
    Re: C1 clutch cross shaft
    Pat--
    That's all there is!! Good lucl! You just pivot and lower the cross shaft and bracket together, and they come right off.
    Mike Ernst
