I am attaching the trailing arms to the spring. Body is off of the frame. I got the right side connected with no problem, but I am having an alignment problem on the left side. When I get the end of the spring jacked up, the hole in the end of the spring is 1/2" to 3/4" to far to the rear to line up with the bolt in the end of the trailing arm. I can get the end of the bolt in the hole, but it is at such an angle that I can't get the seat, bushing and washer on the end of the bolt. I am hesitant to tap on the spring with it loaded up flat. Any tips on alignment?
Steve
Steve
