64 L76 crank - NCRS Discussion Boards
64 L76 crank
  • Jack Beebe
    64 L76 crank
    On the L76 and L84 engines, does the crank dampner bolt on, or press fit?
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 64 L76 crank
    I believe that all the 3782870 blocks from 62 - 65 had press on balancers. Regardless of the horsepower. My 64 L75 dated block had no bolt and when rebuildng it was suggested I add a bolt. The machine shop told me none of the old 327 blocks had bolts.
      Re: 64 L76 crank
      Bob-----
      A 1964 L-75 wouldn't originally have been fitted with a crank snout bolt. However, all 1962 and later SHP 327s did have the bolt. The machine shop might not have seen too many of these since the 62-65 SHP small block applications were pretty much limited to Corvettes.
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: 64 L76 crank
        all dampers are press on even the ones with the bolt.if the press fit is not tight enought it will shear off the key and spin.
        • Clem Z.
          • January 1, 2006
          • 9427
          PS the key is just for alignment *NM*
