C2 rubber mount differential - NCRS Discussion Boards
  • Joseph K.
    • March 1, 1980
    • 168
    Am trying to finish replacing rubber bushing mount for differentialbut can not get bolt hole to line up with fresh bushing in place. Will not allow mount to line up bolt holes. Any help is needed. Thanks in advance...Kirby
  • Joe R.
    • July 31, 1976
    • 4547
    Re: C2 rubber mount differential
    Joe,
    When you removed the older bushings the rear sometimes will tilt up in the front and give some problems. You will have to use a pry bar to get it back down and in alignment.
    Hope this solves your problem.
    JR
