C2 Spring Cleanup - NCRS Discussion Boards
C2 Spring Cleanup
  • Harry Sadlock
    C2 Spring Cleanup
    For those of us in the north that worry about rust, a cleanup hint. Since I have the heater box out for repair I decided to look inside the area behind the air grills. I have a non-A/C 63. What I found was 2 inches of debris that has accumulated over the past 41 years (leaves, pine needles, etc). This is a great place to hold water and allow rust to start, I have some. At the bottom I finally found a 1 inch drain hole to the road that was plugged with garbage. A long soft plastic hose attached to the vacuum will help clean it out.
    Harry
    38513
  • Chuck R.
    • April 30, 1999
    • 1434
    Re: Good Heads Up Harry
    I'm sure there are a few C-3s out there (mine for one) as well with the same condition.
    Chuck
