Harrison Foil Label - 1974 Big Block - NCRS Discussion Boards
  • Lee S.
    • September 30, 2002
    • 156
    What is the correct position of the Harrison Foil Label on the Evaporator Core. I have searched the AIM, magazines, internet, etc. I have also searched the Tech Board Archives here. Many questions on the same issue. The only definitive response I found is listed below and references a 1969 model. I'm not sure I completely understand Larry Barickman's description. My car is a 1974 454 Coupe with AC, Automatic, etc.
    End of Lee Snyder message.
    Reprinted Posting from May 30, 2003.
    69 AC Harrison Label (C60)
    George Dieterle -- Friday, 30 May 2003, at 12:08 p.m.
    What is the correct location and orientation of the Harrison blue and silver foil label? I believe it is supposed to be on the evaporator box, I'm not sure of the exact location. Also, what is the correct part number for the AC relay that is located on the evaporator box.
    Re: 69 AC Harrison Label (C60)
    Larry Barickman -- Friday, 30 May 2003, at 1:15 p.m.
    Mine is the original. It is 4 1/2" down from the top of the evaporator box on the front surface. It is about 3/8" in from the edge closest to the valve cover. Text is readable from the center of the car. (top of letters toward the fender)
    End of reprinted posting
    Same position BB or SB.... *NM*
