'63 Soft Top - NCRS Discussion Boards
'63 Soft Top
  • Jeff Z.
    • February 1, 1994
    • 94
    '63 Soft Top
    Trying to determine if '63 soft top which has been stored under decklid for at least 30 yrs is original, GM service or aftermarket. Top material is small diamond grain, with a thin strip of small "oval" grain material across rear bar. Side edges and rear edges have different grain material. Signs of cleaning tag on left rear. Window is heat sealed to top and has the following on left rear corner:
    "Regalite" inside of horizontal diamond "AS6" "5 04" "Do Not Rub Dry" "Wash With" "Water Soaked Cloth"
    According to JG Regalite tops were only used on early '63s, this car was built 4/63. Date code makes no sense, should be MMYY. However date code is clearly "5 04" and not "5 64".
    Thanks In Advance Jeff Zsoldos
    63 Convert 340 hp
    66 Coupe 300 hp
    67 Camaro 1500 hp
    00 SS Camaro 320 hp
