Fixing reset function on trip-odometer, '63
Re: Fixing reset function on trip-odometer, '63
Ken, I tried just what you said last night and it fixed it! The reset gear looked like a 'star' washer and it was stuck to the housing. It just didn't look like it would move and I didn't want to force it to where it would break. It appears to work OK now.
Thanks for the help.
Gary- Top
There is a spring loaded gear inside the speedometer head. The shaft of the gear has a square hole where the reset cable plugs in. When you push up on the cable, the gear engages the trip odometer wheels. Turning the knob clockwise causes all the wheels to turn backwards to zero. Once they all get to zero, all the wheels turn together. If you overshoot and are showing all nines, you can then turn the knob counterclockwise and advance it one position at a time, getting to all zeros. The knob pushes the cable up about 3/8" to engage the gear. It sounds like your cable is not pushing up enough. You can test it with a scrap piece of speedometer cable and some vice-grips. Push the cable in as far as it will go and turn it clockwise. If the wheels move, the problem is in your cable, if they don't the gear is probably stripped.- Top
Ken, Thanks for the detail response. I understand what you are saying.
After I got the spring loaded gear free, I connected the cable and push on it. The spring loaded gear moved up to the axle shaft that holds the 'number' wheels and the center of the spring loaded gear moved this cone shaped object on the shaft which caused the edge of the spring gear (the teeth) to make contact with another gear on the shaft. This connection of the two gears is how the numbers are reset to zero when you turned the cable. (I am probably telling you something you already know. But, I wanted to say that to ask you another question.) Sometimes when the spring gear touches the cone-shape object, it does not move everything so that the spring gear can make contact with the other gear. Is there something in the cluster of the 'number' wheels that is stopping this from happening? Can I take the number wheel apart and clean it or something? I think that everything on the shaft is held together by a press-fit washer at both ends.
The whole thing is pretty cool on how it works.
Thanks for the help.- Top
I've found the sticking is caused by a varnish like build up from a 38-year old lubrication. I would not advise trying to take the wheels apart. It's real easy to damage the numbers, and because the '63 fat type face is rare, you won't be able to find replacements. I just oiled mine with a good quality clock oil, using one of those clock oilers with the long skinny spout. A hypodermic needle would also work. Mine still sticks occasionally, but after giggling the knob it always seems to work.- Top
