'67 Speed Warning Buzzer - NCRS Discussion Boards
  • Dave M.
    • June 30, 1999
    • 58
    Hi,
    I need to know if I can check a speedwarning buzzer to see if it is working
    or not when taken off the car and checked directly using jumper wires and
    a 12 volt battery without doing any damage to the buzzer, assuming
    it does work?
    Thanks again for your help,
    Dave
    Re: '67 Speed Warning Buzzer
    Dave-----
    Yes, you can check the buzzer off the car as you described.
