U-joint grease - NCRS Discussion Boards
U-joint grease
  • Chuck R.
    • April 30, 1999
    • 1434
    U-joint grease
    I attempted to save eveyone the anoyance of responding to an old topic, but I could not for the life of me find it in the archives, so ........
    I have a gun full of synthetic grease and would like to use it on the new universal joints.
    Question: Am I required to purge the original grease from these new joints, or will both types properly interact with each other?
    Chuck 32205
    Re: U-joint grease
    Chuck-----
    If the conventional grease and the synthetic grease are both lithium based, there will be no compatibility problem. If the bases are different, then, technically, the greases are incompatible. However, for a low speed application like u-joints it really shouldn't be a problem.
    If it were me, though, I wouldn't mix grease types. That's why for my car I use GM #12377985 for all chassis applications except wheel bearings and Valvoline SynPower Synthetic grease #985 (meets GM spec 1051344) for wheel bearings. I keep one grease gun filled with each and clearly labeled as to which it contains.
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: U-joint grease
      Excellent,
      My syn. grease IS lithium based.
      Thanks for getting back to me Joe.
      Chuck
