I R&R the cluster, screwed the speedo cable back and snugged w/ a pliers. The first 35-40 mph, the speedo is 8-10 mph fast, the car catches up and is OK the rest of the way. When I come to a stop, it's still 6-10 mph or so, but usually when I pull slowly into my garage, it's at zero. I did not lube or change cable when the dash was out. I did install the speedo/tach gromet in the firewall; it not have one before. I called Autointruments and he said he callibrated OK. I even snugged it a bit more and made SURE the cable is straight. It starts right away, as the needle kind of jumps as the car starts moving, then stays fast... Any answers or ideas?
Also, the stilt for spark plug wires on pass. side has a 3 then 1 look. Should the holder that is further out be toward firewall or front of car?
Also, the valve cover hold downs under the bolts: should they be orange or cad, like the bolts?
Please let me know your thoughts and ideas...-Bob
