Re: Correction - NCRS Discussion Boards
Re: Correction
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Correction
    Rich:
    First, be sure that your vac gauge is working properly. 20" vac is a bit too high, even for the mildest cam.6-8 degrees initial sounds fine. I believe that it should be 10 with L79, and 8 with L75. Remove the rotor and check the operation of the advance weights. Move them by hand and check for binding, etc.
    Joe
